constance_chlore
Almost identical to three weeks ago, but I took the pictures so I might as well post them.
And you failed?Prior to construction you have to provide an arborist report for the development, including a tree protection plan that is quite comprehensive and commit to a lot of requirements by the City.
Whatever the penalties are, they aren’t high enough. 50+ year old trees need to be valued even more than something like 30k. Such a shame.If a City boulevard tree was damaged by a contractor then there would usually be compensation owed to the City for said tree, depending on what the trees value is assessed to be. This can often be several to tens of thousands of dollars depending on the tree.
I realize that in construction things can happen despite best efforts, so I am not going to jump all over them for this. However, the company does need to be responsible, I agree with compensation being required and feel perhaps it should be even higher.If a City boulevard tree was damaged by a contractor then there would usually be compensation owed to the City for said tree, depending on what the trees value is assessed to be. This can often be several to tens of thousands of dollars depending on the tree.
I know that I am biased, but I love the corner windows/detail.
