archited
@Mattyeg if they are pre-drilled holes then the piles are rightly called columns supporting retaining walls (usually stacked timber); if they are drilled or hammered piles they are still placed with the same results acting as columns retaining a lateral load (cantilevered load).
"A beam is a horizontal structural element which withstands vertical loads whereas columns are basically vertical members which span from substructure to superstructure and play a crucial role in transfer of load from top of structure to bottom footing."
