Infiniti | ?m | 6s | Brian Allsopp
  • I like it a lot
  • I like it
Daveography
Administrator
Staff member
Edmonton, Alberta, Canada
This project started in 2014, and has been on hold for a long time with a partially completed parkade that started to collapse and affecting neighbouring foundations. It apparently was up for judicial sale. Starting a thread as there is confirmed movement on this one now:
PERMIT_DATE February 16, 2018
PERMIT_NUMBER 139507555-021
JOB_CATEGORY Commercial Footing / Foundation
ADDRESS 11711 - 105 AVENUE NW
NEIGHBOURHOOD QUEEN MARY PARK
JOB_DESCRIPTION To complete the construction of an UNDERGROUND PARKADE ONLY for future apartment building - Infiniti.
BUILDING_TYPE Apartments (310)
WORK_TYPE (04) Foundation
FLOOR_AREA
CONSTRUCTION_VALUE 0
ZONING DC1
Original renders, not sure if this is still what is being built:
Source: http://www.brianallsopp.com/site/new_projects?galleryid=59
PERMIT_DATE May 29, 2018
PERMIT_NUMBER 139507555-025
JOB_CATEGORY Commercial Final
JOB_DESCRIPTION To construct a TEMPORARY hoarding (pedestrian sidewalk protection) permit expires 1 July 2019 - ("Infiniti").
BUILDING_TYPE Hoarding (910)
FLOOR_AREA
CONSTRUCTION_VALUE 10,000
ZONINGDC1
PERMIT_DATE June 04, 2018
PERMIT_NUMBER 139507555-019
JOB_DESCRIPTION To construct an apartment building on top of an existing underground parkade (109 dwelling units) - Infiniti.
WORK_TYPE (01) New
FLOOR_AREA 104,112
CONSTRUCTION_VALUE 13,252,000
ZONING DC1
UNITS_ADDED 109
This must be the max height for wood frames? I thought it was four for some reason, but I guess it is six?
I wonder if this was originally marketed as concrete and swapped to wood frame? I don't really know what happened with the condos - did they return deposits and swap this to rentals? Definitely will be a lot noisier and not to the same expectations buyers may have had.
@westcoastjos, I believe the exterior finish was always intended to be EIFS -- it just has a concrete-like "feel" in the renderings. 105th Ave. continues to go through transformation. I am promoting the idea of reducing auto traffic to two speed-limiting lanes (one in either direction and narrower than usual (10-feet instead of 12-feet widths) with the balance of the existing road's breadth then turned over to common-use pedestrian sidewalk with the one-time proposed "freezeway" in array with a 2-lane bicycle path and a tramway extension from the Grandin line that connects to Strathcona -- a linear park-like sensibility with restaurants and bars encouraged to locate along the length -- a true medium density urban street with some flair.
The windows look absolutely tiny for a new building. Is this for better insulation value and cheaping out on windows?
These tend to be small windows on newer woodframe from what i'm used to;
